Atwood 8835 - iv will not ignite - 9 year old furnace
boston_blacky
So, we left Texas earlier this week and are now in Ohio. This a.m. our 9 yr. old Atwood furnace would not start. I can hear a slight sound as if it wants to 'kick in' but no go!
Removed the outside panel and saw a small red light flash on board located to the left. What steps can I take to zero in and correct this problem - before I call in a technician? Tkx. in advance
p.s. We've had no problems with this furnace until now.
BOSTON BLK
4 REPLIES 4
boston_blacky
Here's the good news - the furnace now works. I played around with the wiring which caused the furnace to 'kick in'. Following a 6 1/2 hr. drive to our present location and it's still working fine. Thanks to all to wrote in to help. BB
BOSTON BLK
CavemanCharlie
I don't know about the light. But, most furnace problems are because Wasps (or Mud Dauber Wasps ) have built a nest, or nest's, in the furnace outside vents.
If it can't get fresh air or get rid of the exhaust gases it will not light.
Use a flashlight to look down the intake and exhaust tubes and see if there is anything in there.
Even if you can't see it this could still be the problem. I once removed a furnace, shook it upside down, and dumped a whole coffee can full of wasps nest's out of the plenum.
Ava
When that light on the board turns from green to red, it is trying to ignite. This sounds like a gas flow problem.
Dog_Trainer
Maybe the gap in the ignitor has changed. This happened to mine. I reset the gap and tightened the loose screw that caused it and no more problems. You can find the gap distance in your book or on line. Unfortunately I had to remove the furnace to get at the little bugger.
2016 Newmar Baystar 3401
2011 HHR Toad
Daktari & Lydia Cavalier King Charles , Annie get your guns, our English setter (fur Bearing Children)
