Bob_Vaughn's avatar
Bob_Vaughn
Atwood Heat Pump
Boy did I make a mistake buying this piece of ****.....first off the fan runs all the time when in A/C mode.....this weekend it got into the high 40's so I turned it to heat and it cycled on and off all night....the air coming out of the roof ducts was only 70 degrees when it was running.... inside never got above 67 degrees......could not get gas furnace to come on....when I called Atwood the bimbo I spoke to told me that was the way it was suppose to work because it was too warm inside the camper for the heat pump to work......duh.....If I was her supervisor and listened in on this call I would have fired her because she did not have a clue what she was talking about.......when I told her I had certificate in A/C and knew what I was talking about she brushed me off......so be careful if you are considering a Atwood air command A/C...
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 15, 2026
