seejp's avatar
seejp
bad service at prarie sky rv in coaldale alberta
Just a little heads up about these guys and their work ethics
Took our 5th wheel into Prairie sky rv in coaldale, alberta to have an insurance claim repaired from a tire blowout.
They did a half ass job repairing it, refused to repair it properly, put two different kinds of linoleum in it. hacked the trailer instead of removing the pieces doing the job properly and replacing things the right way!
Never bothered to check if the trailer was winterized and split my hot water tank while they had it from fall until spring. When asked if they were going to repair it said it was not their problem and they quoted me well over $1200 to replace it. THEY BROKE IT!!!!
Just a warning folks don't use these guys or others like them! They don't deserve our time or hard earned money!
Sorry for ranting on but I feel I've been taken advantage of and if by reading this you are saved the same bad treatment I was given by these guys I will be glad.
And if anyone knows of a way that I can recoupe some of my out of pocket costs of having to repair my trailer properly or have someone else fix it right please give me your feedback.
Thanks.
  • Seejp - I see that you posted the same topic in more than one part of the site. That is against the forum rules, so don't be surprised if they delete on of them. I'll post my reply on your first post in case the moderator wants to delete this one.
    Jim
  • Did you remind them that it needed to be winterized prior to dropping it off?
  • File a complaint with your insurance company. If further damage was done as part of the repair process which will require additional outlay, then your insurance company may pay it and go after these folks.
