Feb-06-2014 06:10 AM
Feb-06-2014 11:00 PM
dmcf wrote:
I have a Barker Series 3000 tongue jack this is stuck in the up position. I have taken off the top and tried the manual crank, and it bent the crank. Then I took it apart to see if the pin had sheered off, and everything looks good. I have email Barker several times and they do not respond. Anyone have any suggestions? I was thinking about see if I could find a socket wrench that would fit over the manual override and see if I could work it free. And now I also wonder which way I should be trying to crank it. Clockwise or counter clockwise?
Feb-06-2014 06:58 PM
dmcf wrote:I had a similar problem. My jack would not go up or down. I almost bent the manual crank handle trying to crank it by hand. It seems the motor seized up and didn't want to turn. I removed the cover and removed the gear on the motor and that allowed the rest of the gear chain to work with the manual crank. As I recall there was a little "C" clip that I had to remove to pull the motor gear off the motor shaft.
... I have taken off the top and tried the manual crank, and it bent the crank. ...
Reese Dual Cam Straight Line HP Sway Control
Feb-06-2014 06:56 PM
Feb-06-2014 05:38 PM
Feb-06-2014 08:44 AM
Feb-06-2014 08:28 AM
Feb-06-2014 06:56 AM
Feb-06-2014 06:42 AM
Feb-06-2014 06:27 AM
