โOct-27-2014 11:24 PM
โOct-28-2014 04:55 PM
โOct-28-2014 04:22 PM
โOct-28-2014 11:18 AM
โOct-28-2014 11:10 AM
โOct-28-2014 09:31 AM
D.E.Bishop wrote:bt41 wrote:
New to me trailer (99 fleetwood wilderness) bathroom fan is not working. Previous owner said it just stopped working last summer and didnt know how to fix it.
Dont have a clue were to start to fix this. Dont know if its the fan, a loose wire or ?.....
Hope its just the fan so i can put something a little better in but dont want to order anything til i know what the problem might be.
Any troubleshooting tips would be appreciated.
I would start by spinning the fan blades, if that doesn't help, start removing the interior shroud and the wires should be tucked into the space between the vent housing and the cutout in the roof. Using your trusty DMM check for voltage, of course you could use a test lamp.
I have no idea which fuse or what amperage fuse to check but I'd start in the distribution panel. If the fan motor is bad, and you decide just to replace it, be forewarned they are ungodly expensive. I found complete surplus bathroom vents for the same price as just a motor would be in an RV parts store. If you have to replace the fan or the entire assembly, I'd replace it with a Fantastic Vent style vent assembly. A little more money but I don't think the DW would allow me to use a computer fan.
โOct-28-2014 09:23 AM
โOct-28-2014 09:15 AM
โOct-28-2014 06:50 AM
Fizz wrote:
I replaced ours with a 12v computer fan from an old desktop PC. It does the job and is wisper quiet.
โOct-28-2014 03:07 AM
โOct-28-2014 02:39 AM
โOct-28-2014 02:29 AM
โOct-27-2014 11:50 PM
