โDec-08-2015 03:39 PM
โDec-23-2015 03:36 PM
โDec-13-2015 03:54 PM
Everything else seems to run fine this wayYou could find out for sure with a hydrometer and a meter. If you rely on the plug in voltage meter, you really don't know if your batteries are ever getting fully charged.
โDec-13-2015 02:54 PM
โDec-13-2015 11:05 AM
atreis wrote:
My AGM batteries usually read 13.7 volts. When I turn something on they'll drop pretty quickly to 12.8-12.9 and decrease very gradually from there.
If yours drops to 12.1 as soon as you turn the furnace on, either there's a large voltage drop for some reason (wire too small) or the batteries have a lot of internal resistance (they're nearly shot).
โDec-13-2015 08:18 AM
โDec-13-2015 05:02 AM
โDec-13-2015 04:44 AM
โDec-12-2015 03:09 PM
โDec-09-2015 04:13 PM
wa8yxm wrote:
When you first shut off the charger the batteries retain both a Charge and what we call a "Surface Charge" They can indeed test well over 12.6 Come back in an hour or two and meter them again.
โDec-09-2015 12:24 PM
โDec-09-2015 10:06 AM
โDec-09-2015 05:05 AM
Matt_Colie wrote:
I did a lot of boat work before the depression and I often saw this sort of thing.
Assuming you have a good meter for starters, mine are. It is not uncommon to see a fully charged battery at rest sitting at 13V+. With even the slightest load, the terminal will drop into the high 12s instantly. Turn on a light and they will be a 12.6 in moments. I was told by my "battery guy" (an engineer with Decca) that this is an artifact of "surface charging" where the electrolyte nearest the plates has developed a higher density and has not been redistributed yet. That redistribution can take quite a while.
The condition does not represent or cause a problem.
Matt
โDec-09-2015 03:46 AM
โDec-08-2015 06:34 PM
