fred42's avatar
fred42
Bauer Entry Door Lock Problem
I have this Bauer entry door lock:
The bottom lock is the deadbolt and is the only one we use. It has worked well for years, but today neither of the two original keys open the door. The key is inserted at 12:00, will turn freely back to 9:00, but will not turn at all past 12:00 to get to 3:00 which I seem to remember opens the lock. I have tried graphite key oil, but it did not help.
This is a fifth wheel so I can open the storage compartment and laundry lid on the step to see the lock as shown below:
Unfortunately (I guess), I do not have a small child to send in there. None of my neighbors or friends have one and I don't know where to Rent-a-Kid. :)
Unless you have any other ideas, my next plan was to make a stick with a hammer head type weight on the end to start knocking the turn lever down a bit. Once it has gone a little ways, I should be able to put the end of the stick on it and push toward the door jamb to unlock.
I am very fortunate I am at home when this happened and as usual I can use a fun project/game like this. If this doesn't work, I could break the door glass and have an excuse to order one of those clear glasses that everyone likes. I see the door hinges are exposed on the outside, but it does not look like a freely sliding pin that could be knocked out.
Once I get in, assuming I have not destroyed the lock, I am only going to use the upper, non-deadbolt lock.
  • I just replaced my Bauer door handle/lock with a new one. Cost was under $30 on Amazon including shipping. They did not offer one cheaper with Prime (free) shipping. Maybe five minutes to replace. In my case, it was the upper lock on the handle that went bad.
  • We had the same happen to us. Drilled it out and, because there were also other worn areas, we chose to replace the whole unit with a higher end lock. Glad we were home....made the problem morw tolerable and gave us immediate access to parts that were needed. It was not on the recall list, unfortunately.
  • fred42 wrote:
    Thanks everyone,
    I tried knocking the lever down with just a stick and it would not move. I added a small hammer and it was still very difficult, but I was able to open the door.
    When I disassembled it, I saw what had happened. The deadbolt rotor had a tensioner/clunk position indicator washer fixed to the rotor. Normally small bumps on the washer would just clunk into the slots around the plate hole. But the washer broke and pushed the washer pieces up into the slots locking the rotor. I completely removed the washer and the lock now works fine, just without the usual tension and clunk position indication.
    Nice tool!! It is not a good felling not being able to get into your RV. I was camping when it happen to me. Luckily I keep a cordless drill and bits in my storage compartment. My storage compartment key is always on the same key chain as my door key. I had a couple of spare cylinders with the keys in my tool box so I was able to change the deadbolt cylinder with a new one. Check out the fastecindustrial.com website they have a list of all the recalled key #'s. My Evergreen Everlite key was on the list.They sent me new cylinders with the special key. My key # on my new camper (the one I got locked out of} was not on the list but after I talked to them they sent me the cylinders with keys and the special key to slide out the bad cylinder and put in the new ones. Takes only a few minutes. Good Luck!
  • Thanks everyone,
  • I had a 2012 Evergreen Everlite and my key cylinders were on the recall list.
  • Also if you can get to see it from the laundry shoot can you use a pole or handle and flip the deadbolt lever on the inside of the door? I just read that you were thinking of doing this. That might work.
  • I have had this happen to me last fall. I drilled out the key cylinder and then put in a flat head screwdriver and turned the dead bolt to turn to open the door. Yes you will have to get a new cylinder. I used a bit a little smaller than the cylinder size. I had contacted fastecindustrial.com since they have had a problem with these key cylinders and they sent me 2 cylinders with keys. They also sent me a special key to put in the new cylinders. Real easy to do. You can also go on rvlocksandmore.com and order extra cylinders with the keys. If you do not get the special key you can take the handle off the door and lock the new cylinder from the backside of handle. There's a clip on the cylinder that locks in the back side. You can also order a whole door lock handle with new keys from rvlocksandmore.com
  • Don't know but maybe a locksmith could do the job?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
