  • Two things to remember when pulling onto a tow dolly. Driver should use right foot for the accelerator and the left foot for the brake peddle at all times (assuming an automatic transmission). Person directing should be positioned to one side and never between the vehicles.
    I'm 72, but have lived long enough to have seen stupid things done by drivers of all ages. They usually get away with it.
  • If you have a "DIY" telescoping towbar, no reason for it to ever happen. But many still have a fixed towbar, and a helper holding the TB up makes it a lot faster, Like said above,...don't give it a chance to happen,...just DON'T DO TT !
  • Very sad. I hope the lady was not hurt too badly.
    I hook up my toad by myself. That said inevitably someone in the CG always wants to help.
    I ALWAYS have to tell the person to step aside before I move the toad forward.
    Same thing when hooking up a tow chain to pull some one out, people always want to stand right next to the tow chain. Have to tell them to move way away before I pull.:R
    I have had 2 clips break apart when pulling someone out and those hooks become guided missiles flying fast enough to lop your head clean off.
    Sadly some people just don't think ahead about safety.
  • Easy to let your guard down. The coach is in park when we are hooking up and we both stand off to the side when backing up.
    Those radios are nice but it takes a second when you key the mike. Using the cellphones next time for that.
    I hope she gets well quickly.
  • Hooking up our toad safely:
    First, I configure the tow bar to approximately the right location to connect to the toad baseplate - spread out to the right width + half way between all the way compressed and all the way extended.
    Second, I drive the toad up to be close to tow bar arms and closer to the RV than the final spacing.
    Third, I get out of the car and look, and if necessary I jockey the car around to be about where I want it (lined up with the tow bar arms, and closer than they will be when the arms extend and lock).
    Fourth, I connect the ends of the shortened tow bars to the base plate.
    Fifth, I back up the toad to latch the tow bars at their extended lengths.
    Sixth, if I can't quite get it right, I have DW get in the car and make some slow short movements - forward or back plus left to right - until both tow bars latch.
    Even if she gunned it, she couldn't squash me because I'm standing to the side, and the collapsed tow bar arms will stop the car before it can get all the way to the RV.
  • Life has several danger zones, doesn't it? This one to be sure, but also underneath any heavy object whether hoisted by a crane or a come-along, or even just held up by your brother-in-law. Middle of an open field during a thunderstorm. Be careful out there, folks.
  • Jack_Diane_Freedom wrote:
    Sincerely hope she has a speedy recovery. Maybe time for hubby to give up his license.
    If everyone gave up their drivers license when they did something stupid, the roads would be pretty empty. :)
  • Danger Zone........any time you place yourself between two vehicles and one has a 'occupant'
    Just Don't Do It!.......PERIOD
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
