Bigger Tires?
ajriding
I am at the point I need almost all new tires, 6 of them.
I have 225/75/16 (I think I remembered the #s correct, these are the standard class-c tires) Would going to the next bigger size (larger diameter) help with fuel economy?
I have been told it would since the engine running rpm would be lower, but do not have positive proof. If anyone has done this then that would be the person to respond.
22 REPLIES 22
pianotuna
Nomad III
Nomad III
Hi Phil,
I could not do that size exchange--I was overweight on the driver's rear.
Grit dog my tires absolutely required a different offset. There are "cheaters" that can be used--but they are not recommended for heavy vehicles.
Regards, Don
pnichols
There is a very easy way to go up in tire size slightly for slightly better fuel economy and more ground clearance without changing your rims and without worries of the dually sidewalls rubbing.
Go "up" to 215/85R16 tires of the same Load Rating as your current 225/75R16 tires. I ran stock 225/75R16 Load Range E tires on our Class C motorhome for several years before switching to 215/85R16 Load Range E tires around 3 years ago. The 215 tire actually has about a 1.2 inch larger diameter than a 225 tire, so all gears are just a bit "taller", for better mileage. Load Range E is Load Range E, so both tires can carry identical maximum loads. A 1.2 inch larger diameter provides 0.6 inches higher road clearance for the entire vehicle, including all suspension and drive components and all coach components. The 215 tire is slightly narrower than the 225 tire, so spacing between dually sidewalls is wider to better guarantee no sidewall rubbing and there is another advantage - more air flow between the dually sidewalls for improved cooling of the tires in hot weather travel. Also, another advantage seldom talked about is - at any given loading - reduced tire tread wear when tire diameters are increased.
Of course I had to buy seven (7) tires at replacement time (a new spare, too) to change to the larger diameter tires, but I need only buy six(6) from now on. I now use Michelin LTX M&S2 215/85R16 tires.
Any loss of power from the larger diameter is insignificant, since we have an E450 chassis under our small (24 foot) motorhome instead of an E350 chassis. The E450 has more pulling power due to it's lower rear differential gear ratio, slow larger diameter tires have no effect that we can feel when pulling grades. The speedometer now has about a 1.5 MPH under-speed reading error at cruising speeds, but that is of no concern to us.
I have run over-stock-diameter tires on some of my vehicles for years with no negative effects whatsoever.
2005 E450 Itasca 24V Class C
Grit_dog
Navigator
Navigator
Not going to hurt a bit to put 235/85 or 245/75 on. They are not much wider so rear tire spacing shouldn't be an issue, but measure first.
As long as they don't rub at the bottom you're fine.
Not certain what cooling has to do with it. If there's an air gap between your tires your fine.
ajriding
The engine will produce less power at a lower rpm, but this 460 will chug up almost any hill in over-drive, so I have some power to spare.
Cooling is something I have not thought about, has anyone had real experience with this?
Pianotuna, what vehicle and engine did you put your bigger tires on?
pianotuna
Nomad III
Nomad III
Hi,
I bought new wheels and went to 235/85r16. It gave me about 1 mpg improvement. It improved ground clearance as well. In addition the tires have more carrying capacity.
Regards, Don
Ed_Gee
Assuming you are speaking of a class C RV, you need consider the spacing between the rear dual tires. Cooling is a factor and bigger tires may decrease that cooling... might even cause other problems.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
majorgator
It is a fact that going up a size or 2 with tires will increase your mileage, increase performance, and provide an overall better driving experience...on some trucks....with some tires. Your results may vary....
SAVED BY GRACE, THROUGH FAITH*
1998 Coachmen Catalina Lite 248TB
TV: 1996 F350 Crew Cab 4x4 7.3L Diesel (a man's truck)
*signature amended so that religious components aren't included (per "Admin")...hooray, now nobody will be offended by my personal beliefs
Terryallan
Yes the engine would be turning less rpms. But it would also be making less power, and you would lose towing capacity, and your engine would be working harder when towing, actually causing MPG to decrease.
My TV gains 500lbs of towing capacity just by dropping to 17" tires. Larger/ taller, or shorter tires effectively change the rear gear ratio of the truck.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
