โSep-06-2016 07:34 AM
โSep-11-2016 10:13 AM
twxsby89 wrote:
Just returned from a nice long weekend getaway, and our black tank sensors are again reading full (after dumping). I just want to ask if you think a hose sweeper nozzle would be to hard on the inside of the tank. Going to rig me up a spray wand I can blast the inside of the tank with, down though the toilet. I just don't want to hit the sensor with too hard a stream, and damage them.
Thanks
I have a hunch my 6 year old is still flushing wipes down there.
โSep-09-2016 06:48 PM
โSep-09-2016 04:20 PM
โSep-08-2016 10:41 AM
โSep-08-2016 08:55 AM
twxsby89 wrote:
THanks for the replys, I took the rig to Storage (that has a dump), and filled the black tank twice, and got the sensors to read empty. I then filled it back up about half way, and added Calgone and Dawn. Left it filled with this. I will empty before our next trip.
โSep-08-2016 06:57 AM
โSep-08-2016 06:47 AM
โSep-08-2016 06:27 AM
โSep-06-2016 11:19 AM
lanerd wrote:
You know you could probably eliminate this problem if you would, prior to traveling, empty your tank and then add about 5 gallons of water to it. Then add a cup full of liquid laundry detergent (I use Oxy-Clean) and about a cup full of liquid Calgon water softener.
During the drive home, this solution will slosh around in the tank and loosen just about anything in there from the walls of the tank and the sensors.
Upon getting home (or close to home if you don't have a sewer access) and drain the soapy solution and rinse with a tank full of clean water and drain once again.
I always leave several gallons of water in my black tank, even when in storage.
Hope this helps
Ron
โSep-06-2016 10:41 AM
โSep-06-2016 09:56 AM
โSep-06-2016 09:09 AM
DrewE wrote:
Spray wands are not expensive to buy pre-built, for what it's worth. You can get a basic PVC one for under $10 at Wal-Mart.
โSep-06-2016 07:52 AM
โSep-06-2016 07:48 AM
