partimcmpr
Jul 20, 2015Explorer
Blue Ox Sway Pro BXW2000 - shank size
I have a new trailer which has a heavy tongue weight(TW). Having used the older sway pro in the past, I decided to go with the Blue OX Sway Pro BXW2000. It came with a 2 1/2 inch weight distribution shank. My installing dealer had just installed a truck hitch with a 2 inch receiver. Try as I may, I just cannot get that 2 1/2 inch shank in the 2 inch receiver! ;)
When checking the TW specs on the various shanks, I am finding conflicting information for the shanks. The BXW2000 ships with the 2 1/2 inch shank, so I would hope it is rated for up to 2000 lbs. tongue weight. But I have also found it listed on the blue ox web site at 1500lbs. TW. I have also found the 2 inch shank listed at both 1500 and 2000 pounds TW.
Anyone done research on this, or know for sure if the 2 shank can support 2000 pounds TW?
Anyone using the BXW2000 with the 2 1/2 shank? Or with a 2 inch shank?
Thanks in advance!
ParTimCmpr
Thanks in advance!
ParTimCmpr
