nwbearcat1998
Aug 13, 2014Explorer
I successfully installed hte Blue Ox Sway Pro BXW1000 hitch last night on my F-150 and couldn't be happier!! The rear end (wheel well to ground) dropped only about 1" and the front end stayed the same. The ride is so much smoother.
I'd really enjoy hearing some specs from the other guys that use the Blue Ox sway Pro on the amount of drop in rear and the number of links you used on the bars. I ended up using 9 links.
Heap64, could you please check the socket size on your breaker bar? I can see that being a HUGE help for latching chains.
Thanks in advance!!!!
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 24, 2025
