Bought the Simply Go
Don___Barb_Bogu
I haven't ben on oxygen very long this time. We took a piece of paper and drew a vertical line down the center and started listing pro-and con on either side of the line. we do this with all major purchase. it came out to be $ 2125.00 a couple of hundred less than expiated .Started using it today very happy so far. the battery seams to recharge very quickly. I was impressed with the quality of every thing in the shipment.
5 REPLIES 5
Don___Barb_Bogu
This oxygen concentrator comes with a battery. there is also a AC and a DC charger.the two wheel cart is very sturdy. We also bought an extra battery. the machine (on 2.5 le ) will run the machine about 4 hours on the battery only. The 120 v ac charger takes about 4 hour to charge it back up while supplying O2. The case that the machine slips into seams to to be well made, as does the extra pouch for the chargers.
pianotuna
Nomad III
Nomad III
I think they purchased an oxygen concentrator with a battery.
Regards, Don
PenMan
DownTheAvenue wrote:
x2
Chris and Jane
2013 Open Range Journeyer JT337RLS
2006 Dodge Ram 3500, 4x4, Crew Cab, DRW, 5.9 turbo diesel
1996 Harley Davidson Electraglide
DownTheAvenue
Lwiddis
Please do a longterm report too.
