Cheryl1964's avatar
Cheryl1964
brakes for a tahoe
my husband and I have a 2002 tahoe, and we are buying our first trailer, so we have installed the trailer brake controller inside the cab, checked all fuses, but yet we do not have any power at the plug next to the hitch, any ideas?
  • What power is missing? The trailer brake? The 12V charge line? Lights and / or turn signals?
    Does the brake controller you installed light up (have power to it?)
    On my '04 GM I had to 1) install a fuse on the under-hood fuse block and 2) fish back through the wiring harness a few inches, find the 12V charge line w/ ring terminal, and buy a 6mm nut to put it on the fuse block stud.
  • If I remember correctly unless the key is in run position you wont. But under the hood fuse panel on drivers side there is a dummy fuse. Position two I think. Also you need to verify that there is actually power to the fuse. On some GM vehicles the power wire is not connected.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Mar 04, 2025
