madonetwo
Jan 29, 2017Explorer
Breakaway brake pin is stuck and can't be removed easily.
Hello, we have a B&W turnover ball gooseneck hitch towing an Open Range Light 5th wheel. We bought it, towed it home, backed over the flowerbed, made some tight turns and the RV brakes locked. Figured out the next AM that the pin had come out of the breakaway brake device on the hitch. Husband placed pin into assembly and brakes relaxed and wheels roll. Next day went to unhitch and the pin is stuck in the device and won't come out. What to do? Pull hard with pliers? If comes out and brakes are engaged, then call for roadside assistance ( we are under warrantee and have GoodSam Platinum). or if comes out, re-engages and brakes work ok, have we done any damage? Phone call to on call service rep said, "tow it to service center". That's about 60 miles at the closest. Is not convenient to tow unless absolutely necessary. Thanks in advance.
