MetalGator
Aug 09, 2018Nomad
One of the reasons I suspect the batteries is on our last trip, when I turned on the inverter, instead of showing the voltage it showed three zeros. I turned it on and off and still 000. I started the generator and then turned on the inverter and it showed a little over 13 volts. I spoke with a local RV tech and he said it sounded like a battery issue. When the slide starts moving out the motors sound normal and it extends fine. But after a few seconds I hear both motors start to slow down and it seems to struggle. Doesn't do it every time but only the last two trips.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 17, 2025
