Can i turn the Inverter Off?
thirtydaZe
If the campers plugged in? New rig has a residential fridge, if im plugged in do i have to be running the inverter too?
2019 Jayco Eagle HT 324BHTS
2024 Ram 2500 68RFE
11 REPLIES 11
hershey
Mine is a combo unit and I never turn on the inverter unless I actually need it. Charge still stays active and since we seldom dry camp, I leave it set to charge at the minimum rate. I seldom have to add water to a battery.
hershey - albuquerque, nm
Someday Finally Got Here
My wife does all the driving - I just get to hold the steering wheel.
Face Book Group: All About RVing and We Fly RC's
Expedition - Chevy Equinox
horizon36
My inverter has been on since 2010 because we have been places where there are power interruptions. This keeps all our electronics from rebooting. We have been in Yellowstone NP since June 18th and the power goes out here at least once per week.
It won't hurt to leave yours on.
Live Long and Prosper.
Home is where we park it.
FT since August 2010
'02 Itasca Horizon 36LD
'02 Jeep GC toad
MrWizard
Moderator
Moderator
is it a deicated stand alone inverter
or is it an inverter/charger combo
it it is a combo unit, the charge function must be on, and leaving the invert function on, while camping will not hurt anything
it will charge batteries when shore power is present, and automatically switch to powering the ridge etc.. when shore power is unplugged
i would only turn it OFF when it is parked in storage mode not being used
I can explain it to you.
1997 F53 Bounder 36s
tatest
Talk to the dealer or dig into the instruction manual. If you have a whole house inverter, shore power could be feeding through. If it is just the refrigerator circuit, you need to understand what happens when on shore power. Does that circuit switch over, or is it still fed from the inverter?
Tom Test
Itasca Spirit 29B
thirtydaZe
Yep, it appears to be cooling just fune.
2024 Ram 2500 68RFE
12th_Man_Fan
Yes, you can turn the inverter off when plugged in to shore power.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
CA_Traveler
Try it with shore power as some inverters pass AC though when on shore power. ie They have AC transfer capability.
2014 Grand Cherokee Overland
Bob
thirtydaZe
They said my fridge will run on the inverter when we're driving down the road. They didnt really specify anything else and i didnt think to ask.
They did however leave the inverter in the on position. I have a 30a plug in my garage that i have been plugging my rvs i to for years.
Just figure why be running the inverter if i dont have to on shore power.
2024 Ram 2500 68RFE
portscanner
Are you talking about an Inverter or a Converter ?
Inverter takes 12VDC and turns it into 120VAC
Converter takes 120VAC and turns it into 12VDC
If it is the Converter, you want to leave that on when you are connected to shore power. It maintains your battery and provides the 12V needed to operate most/all lights in your RV and in many (not all) RV's the 12V is required to properly operate the water heater, air conditioning and/or furnace
One beautiful wife -Trooper and Doc the furcampers
2019 Dodge 4500 Flatbed with 2013 Chalet TS116 http://www.brittanynews.us
darsben
probably needs to be on for 12 volt lights, and furnace
Traveling with my best friend my wife!
Ivylog
Depends if it has a transfer switch with the inverter. Turn the inverter off while on shore power and see what happens.
Upgraded with a 08 HR Navigator 45โ€™...
