โApr-17-2015 06:58 PM
โApr-19-2015 03:26 AM
mlts22 wrote:
If there is a 15 amp cord, might as well use a power strip with a switch on it as the means of cutting power for plugging/unplugging, if there isn't a SWD circuit breaker nearby.
โApr-18-2015 09:12 PM
โApr-18-2015 12:25 PM
myredracer wrote:
Electrically either way will work but generally speaking, the fewer the plug/connector connections the better. My choice would be the 50-15 in the link. A dogbone adapter is also preferable over a puck style.
One thing you should do is always turn the power off before plugging in (either at source end of power cord or inside an RV) otherwise you can end up with pitting on the contacts and dirt buildup leading to overheating. Ensure plug blades are kept clean. Had two 15 amp extension cords go up in smoke in our driveway in a short period to time from failing to shut the power off. Now have a 30A recept. c/w disconnect in our carport.
โApr-18-2015 10:14 AM
โApr-18-2015 05:42 AM
dee74 wrote:
My question I have, is it safe to connect the adapters together or should I purchase a separate 50 amp to 15 amp adapter like this one 50 to 15 ?
โApr-18-2015 03:58 AM
โApr-18-2015 03:44 AM
โApr-17-2015 10:42 PM
โApr-17-2015 08:26 PM
Old-Biscuit wrote:SDcampowneroperator wrote:
Its likely safe because the camps breakers will not let you overamp their system.
Camps are wired in 2 ways, the old 'spider' system in which each pedestal is individually cabled to the master panel and its breakers there.
Newer camps may have 'loop' cabling which has master breakers sized to the cabling and maximum load at the distribution panel with individual panels controlled by breaker sizing in them. Both are NEC approved.
What you are suggesting to do with multiple connections into a single power point will not give you a higher voltage unless the ped. is wired with L1 & L2, 120v. each. Most 30 amp ped's are L1 only.
You cannot draw a higher amperage from the pedestal than its breakers allow at either location.
Talk to the camp staff and your electrician about using combination devices.
:H
OP is just wanting to plug his 50A TT into a 15A outlet using 2 adapters and his power cord.
โApr-17-2015 07:40 PM
โApr-17-2015 07:37 PM
โApr-17-2015 07:33 PM
โApr-17-2015 07:30 PM
โApr-17-2015 07:18 PM
