yukonpete's avatar
yukonpete
Can my F150 tow this? Thanks
Hello from the Yukon!
I have a 27ft travel trailer with a maximum tow weight of 6500 lbs. Can I tow this within my trucks limits? Is my calculation right?
My truck
2012 F150 Supercab, 5.0 V8, 145" Wheel Base, 3.55 Ratio, Max Trailer Weight 7800 lbs. GVWR 7350 lbs, GCWR 13,500 lbs.
My truck weight is 5832 lbs
So from my calculations
GCWR 13500 - Trailer Weight 6500 - Truck Weight 5832 = 1168 lbs under the GCWR. So I should be ok if I have done this right?
I am using a wight distribution hitch rated at 10,000 lbs TW 1000 lbs.
Thanks
Pete
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 17, 2025
