1mtnman
Jun 05, 2017Explorer II
carbon monoxide detector
I have a 2014 Northstar truck camper and have been getting alarms of a steady beep now and then. The red warning light come and remains on until I depress the test button. I have checked each propane connection with soap and water and no sign of any leaks. I have also checked the tank and the alarm occasionally goes off even when the tank is turned off. The detector is hard wired into the batteries and the batteries are above 13 amps at all times as they are solar powered. I have purchased a First Alert 10year detector and placed it very near the hardwired one and it does not alarm at all. I'm thinking the that even though the hardwired detector that is OEM is only 2 years old it may be bad. I have purchased a OEM and hopefully that will correct the problem.
What say you?
What say you?
