Probably this stuff linked below. At least mine was 1 inch wide. Your right, just covers screws, but also keeps some junk out. Looks a lot better with trim in than without. Being thin vinyl it gets stretched out of shape by just being exposed to weather after awhile.
I wouldn't put stainless screws in. They are usually much better in most RV applications, but not in this case IMO. When you use the cheap zink screw, you have also just screwed in a "moisture" indicator. Later on if you ever have to track down a water problem, you can pull a few screws and look at the zink coated screw and will be able to see how much rust is on the screw to have better indication where water might be getting in. One of the few times when "cheap" pays off IMO.
http://www.amazon.com/Camco-25202-Vinyl-Insert-White/dp/B0006JLW5M
