gypsmjim's avatar
gypsmjim
Converter and Battery Charging Issues
We have had the 195RB for 2 months now. It is permanently set up on our own private camping property and my only source of power is a Yami inverter generator. Everything has worked flawlessly. However, when I first fired up the generator and checked the voltage I found the battery was not charging. When I wiggled the fuse the fan in the converter started up and it went to 13.5 volts. Since then, same thing. Out of 10 times, 8 times i have to wiggle the fuse to start the charging.
Comments...advice?
  • Try a different fuse. Also might have a cold solder joint on the board.
    Jerry
  • That DOES fix it. Until next week when i have to do it again...
  • Remove and reinsert the fuse. If that doesn't fix it, look for loose wire or connection.
    May have to have an electrical person help you.
  • The main fuse panel has several circuit breakers, plus a row of automotive type fuses. The fuse that I referred to I believe was called the converter fuse, since it was the one that controlled the charging of the 12v battery.
