CoolTech tow harness knocks out left tail light
Freightguy
Ok, wondering if anyone else has run into this. I had a 2007 Jeep Wrangler JK. I just bought a 2011 Wrangler JK and took the cooltech harness out of the old one and put it in the new one. When I hook it up to the left tail light in my Jeep it stops that tail light from working. What gives?
Thanks if you know.
2009 American Tradition 42P
2011 Jeep Wrangler Unlimted
3 REPLIES 3
Thunder_Mountai
Does your 2011 have a factory towing package? If it does, you have to make a secondary connection. Check the instructions. Our 2012 Rubi came with the factory towing package. As a part of the deal the dealer had to pull the Cooltech from the old Jeep and install on the '12. Took them three tries to make the left light work.
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2020 Keystone Outback 327CG
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
jhlady
Freightguy,
I have a 2009 JKU and had the same problem. I fixed it by playing with the connections from the CoolTech wires coming from the front of the Jeep to the light connections. Somehow had them hooked up wrong and it was by-passing the left hand lights. Works now.
Hope this helps.
Dog_Folks
Check the ground carefully.
Bad ground is the most common problem with all items being towed.
Our Rig:
2005 Dodge 3500 - Dually- Cummins
2006 Outback 27 RSDS
We also have with us two rescue dogs. A Chihuahua mix & a Catahoula mix.
"I did not get to this advanced age because I am stupid."
Full time since June 2006
