Calkidd's avatar
Calkidd
Disk Brake Conversion Hub question
I have been doing some searching to no avail, but I know the answer is out there. When I comes to converting your electric drum to disk brakes there are a few kits to choose from. But why $500 for a disk hub, backing plates and calipers? Example; when you purchase hubs for your truck you don't pay more than $50 for the hub maybe $30 for a caliper and $20 for a set of pads? Quite the mark up eh?
So, what automotive disk hub will install on a Al-Ko 7000 lb axle? I can't help to think there is a 3/4 ton or 1 ton truck hub assembly that will fit on the spindles.
Any thoughts?
1 Reply
  • The kits contain other necessary items, like brake lines, mounting hardware, and actuators. Hub and brake rotor are also a single unit on the kits I've looked at. You'd have to find a truck that uses bearings that fit the trailer spindles, and hubs that accommodate the length of the spindle. You would need to figure out a way to mount the calipers too.
    In the end the kit is probably cheaper.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 07, 2026
