Disposing of old 2 cyle mixed gasoline
DD716TED
I have about 1 gallon of old (1 yr) gasoline that is mixed with 2 cycle oil... I have no more items that use this fuel.. How or where do I dispose of it legally? None of my neighbors have 2 stroke engines so no one to give it to..I live in the city so can't burn it, I won't pour it on ground, local hazmat facility won't take it, and fire dept has no clue.. How have you SAFELY disposed of old gasoline?
31 REPLIES 31
old_guy
your truck will burn the oil mixture much better than your lawn mower will
Lwiddis
“Chebby,” MLF? I can’t afford a Pontiac.
Lwiddis
MrWizard, who uses gasoline additives in 2018? Andy Grantelli is long DEAD,
MFL
Nomad II
Nomad II
Lwiddis wrote:
You may be right but I wouldn’t pour old gasoline much less mixed with any oil into my Tahoe’s gas tank. No way.
Oh come on, that Chebby is probably flex-fuel anyway! That means it can handle most anything.:C Don't forget, most oils used to mix for small engines have stabilizer in them, so gas will still be good too.
Jerry
MrWizard
Moderator
Moderator
poor it in the gas tank of one of your vehicles
the results are NO different than, adding some 'top oil' gasoline additive from the parts store
will not hurt your car, truck or RV
I can explain it to you.
1997 F53 Bounder 36s
Bumpyroad
did it contain ethanol? one gallon, just pour in any automobile.
bumpy
time2roll
I would worry about the oil contaminating the catalytic converter. Small engine is fine. No concern about the age of the fuel.
fj12ryder
I'd shake it up and mix it good, put in my vehicle and run it. I've run 5 year old gasoline before, no biggie. Just don't fill the tank with it. 🙂 And double check for any water in it. One gallon in 20 gallons you'll be fine.
Howard and Peggy
"Don't Panic"
RambleOnNW
I mix year old gas (w/Stabil) into one of our cars 1 5 gallon can at a time with no issues. This is our emergency gas supply for our home generator. When it gets a year old then I replace it. Have 2 5 gallon gas cans and 3 gallons in the generator tank.
I will then fill up the car gas tank full to dilute the old gas.
2006 Jayco 28', E450 6.8L V10, Bilstein HDs,
Roadmaster Anti-Sway Bars, Blue Ox TigerTrak
Iraqvet05
I would put it in a mower or other small engine. At work, we frequently run out of regular gas for our mowers and in a pinch I have used pre-mixed 2 cycle gas to get by.
2017 Ford F-250 6.2 gas
2018 Jayco 28BHBE
US Army veteran
Lwiddis
Old-Biscuit
Simple solutions ^^^^^^^^^^^^^^
:S
Trackrig
jmckelvy wrote:
EV2 wrote:
Just mix it in a little at a time with a fill of your vehicle. The very small amount of oil will simply burn away as an upper lube.
Agree. Just pour it in your truck gas tank and burn it. It will work fine.
X3 - it won't hurt your vehicle in the least. Have done it several times over the years.
Bill
jmckelvy
06 RAM 3500,Dually,CTD,Auto(ATS Stage 1),QC,4X4,PacBrake,Spyntec Freespin Hubs,60 Gal Titan Tank,EFI Live, Line-X,Torklifts and SuperHitch,Fastguns
2013 Arctic Fox 990, 275 Watts Solar, 2 Grp 31 AGMs
US Navy 1964-1968, 2-Tour Vietnam Vet
Lwiddis
Most cities and counties in our state have hazardous waste disposal methods for citizens. I’ll bet Washington does too.
