ktmrfs
Jun 11, 2021Explorer II
spoon059 wrote:
Leave a roof vent cracked.
Use an electric heater rather than propane heaters.
Run a dehumidifier.
Damp Rid won't hurt, but might not provide enough, in and of itself.
no difference between electric heat and propane furnace. both just heat the inside air, nothing else.
Now propane oven or stove will add water to the air from combustion, about 1 gallon of water per gallon of propane burned. But furnace will NOT add any water to the air in the trailer, it is all vented outside.
Propane unvented heaters, another story, they also dump water into the air.
If you have humidity problems, go to a big box store and buy the smallest compressor driven dehumidifier you can find. It will do the trick.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,101 PostsLatest Activity: Jan 14, 2025
