Does Furnace Run on DC Power??
BigSur2
A friend and I are planning a trip where we might have to stay overnight in a parking lot the first night in. We both have TTs. Can we run our furnaces off of DC Power?
BigSur2
2016 Jayco White Hawk 33RSKS
41 REPLIES 41
westend
The better idea is to have a heating appliance that doesn't use electricity.
This "Sportsman" stove is in it's third RV:
No longer sold, BTW.
When the stove was installed in a deer camp trailer near the Canadian Border, we usually dialed it back to idle on even the coldest nights. The input rating is 20K BTU. There are similar fishouse stoves that are also vented.
'03 F-250 4x4 CC
manualman
rhagfo wrote:
manualman wrote:
Why are full size RV furnaces such power hogs? Our popup furnace will keep our camper (24' when open) at 50 degrees overnight when the outside is 30 for 4 to 5 nights (off in the day) on one G29 deep cycle! And we have ZERO insulation with those canvas walls. Just how hot you guys trying to keep it in there? And why? Get some blankets.
Or maybe popups just have magic furnaces...
while you may be 24' when open, you are only heating to 50 degrees. I heat to about 60 degrees.
Then there is the measurement, it isn't the length you are heating it is the cubic feet of space. I would guess a 24' TT would have at least twice the cubic feet of space to heat as a popup. Then a 32' 5er like we have way more cubic feet.
I think another poster nailed it. Pups aren't ducted, so our total draw is only about 3.5 amps. Double the amp draw seems a steep price to pay for ducting. I'm surprised more makers don't offer an efficient furnace unit in fixed height RVs like the popups have. There have to be plenty of people out there who want to dry camp and would rather have a few nights worth of furnace run on one battery than even heat distribution for 6 hours of ONE night!
Strabo
bikendan wrote:
In case you don't know, the furnace runs ONLY on 12vDC power, not shore power.
The furnace fan and lighting are 12vDC. Shore power only recharges the battery.
Of course you also need propane.
No it doesn't, the converter manages the feed in.
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 686 SS106-ITP-AFE-BRP-T4-CDI-KIBBLEBWHITE-CVT-TSTICH-Ridgid LED LightBar-HID Conversion Kit-LIVEWIRE
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
rhagfo
mr__ed
I agree that the draw on the batteries will be fairly heavy. Perhaps running the temp as low as practical may extend the time the furnace may be run before drawing the batteries down.
Another consideration is if the blower slows down, the sail switch may not actuate, thereby shutting off the gas to the furnace. Of course, any heating would then stop while the fan motor continues to draw down the battery.
Mr. Ed (fulltiming since 1987)
Life is fragile. Handle with prayer.
2007 Hitchhiker II LS Model 29.5 LKTG (sold)
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition (sold)
rbp111
BigSur2 mentioned that he has a portable propane heater that is safe to use inside the trailer. I have a Mr. Heater-Big Buddy which I use in my fifth-wheel trailer. I would advise BigSur2 that is the way to go. You can utilize the devise which refills the small propane tanks from a larger one, say a 20lb tank. That is much cheaper than have to purchase the small tanks. Or he could do what I did, that is have a quick connect put in the trailer and go directly to the two 30# tanks.
I would recommend a the use of the portable propane heater because, in my case, it has a battery (3 D cell batteries) which operates the fan. And if you don't have the fan, that is ok, it still heats up the trailer in time. But as the people have said before me, the trailer heater will use up the battery power in no time.
PawPaw_n_Gram
The blower fans are the power hog. In some rigs, a blower for a 35,000 BTU furnace can pull as much as 8 or 9 amps. One blower circulates the air inside the rig. The other blower brings outside air into the comustion chamber and back out the vent.
Setting the blower to use the lowest speed possible will extend battery life.
Full-Time 2014 - ????
โ€œNot all who wander are lost.โ€
"You were supposed to turn back at the last street."
2012 Ram 2500 Mega Cab
2014 Flagstaff 832IKBS TT
bikendan
popups have way less power drains than other RVs.
PawPaw_n_Gram
YES
I left my thermostat on when storing my first TT once. Went back to check on it about 6 hours later. Two big batteries deader than my first marriage.
time2roll
The ducting is bad and it draws 2x the battery power(or more).
I assume your PUP furnace vents direct to the living area.
I ended up adding two additional vents to get some heat into the trailer.
manualman
atwowheelguy
I found out that one group 24 won't run the furnace through the night with a 24' camper. I have bought a second group 24 to add, but I'll have to modify the battery rack to squeeze it in. Seems odd that the toy hauler manufacturer made a battery rack that won't hold two group 24 batteries with battery boxes.
I'll hook up the generator next time I try it, just in case the two of them together won't make it through the night.
2013 F150 XLT SCrew 5.5' 3.5 EB, 3.55, 2WD, 1607# Payload, EAZ Lift WDH
Toy Hauler: 2010 Fun Finder XT-245, 5025# new, 6640-7180# loaded, 900# TW, Voyager wireless rear view camera
Toys: '66 Super Hawk, XR400R, SV650, XR650R, DL650 V-Strom, 525EXC, 500EXC
mowermech
When we bought our first motorhome (Class A Pace Arrow), we immediately learned that an 8D battery, fully charged, will be dead by 3 AM running the furnace.
For those who don't know, an 8D battery is one of those 12 volt units that is a little bigger than 2 group 24 batteries!
Getting up at 0300 to start the engine so you can start the generator, in 35 degrees temperature, is NOT fun!
But, to directly answer the question, YES, 12 VDC power and propane are the only things necessary to run the furnace.
CM1, USN (RET)
2017 Jayco TT
bikendan
bukhrn
Bobbo wrote:
We found out in 2011 while in Yellowstone National Park in November, that we had to have the heat turned down to 50 at night, or the 2 batteries would be dead by 2am. We learned to snuggle under the comforter, and turn the heat back up in the AM.
That is exactly the place I learned about running the furnace & batteries.
As a NewB in '08 we were at Madison CG, it got down to 30F, so we ran the furnace at about 65 all night, sometime in the early AM, DW noticed that the furnace was no longer running, granted, it was only 2 27 series batteries, but they were dead in the morning,
As a side note, this is also where I learned about the Altitude adjustment on the Onan generator. :B
2007 Forester 2941DS
2014 Ford Focus
Zamboni, Long Haired Mini Dachshund
