treeview's avatar
treeview
Dolly/towbar/trailer
Until a week ago I had an Aluminum Trailex tow dolly that was going to haul my '96 Tracker...4wd...5spd...2 door... that weighs around 2,600#
The dolly was locked up but someone snipped the cable and stole it.
Now I'm back on the market.
I started researching dolly's and towbars with brake systems. I've got some rough costs.
Then I thought about getting a flat deck trailer. Simpler and multipurpose too. I can find one cheaper used than trying to find towbar/brake setups.
Am I missing something? Why wouldn't I go with a trailer?
I did my homework and looked back 12 months on this forum but didn't see this being discussed
Thanks
Tom
  • Yup..in my head I had the complete info but the thought didn't make it to my finger tips.
    On another thread I found the Ready Brake:
    http://www.readybrake.com/
    Now onto base plates and tow bars
    Four down does simplify life a lot!
  • OP edited his original post to give more information. Original post did not state whether it was 2 or 4 wheel drive.
    Defintely tow four down!
  • I have towed 4 down, dolly and trailer.
    I found 4 down to be, by far, the east and most convenient.
    If I were in your shoes I would be looking for a toad that supports 4down towing.
  • My 2003 has the same specification for towing. 2 wheel drive rear end first.
  • enblethen wrote:
    Is the Tracker 2 or 4 wheel drive. If 2 wheel drive it cannot be towed four down. Using a dolly needs to be rear end on dolly.
    Trailers are heavier for total weight then dolly.
    Only option if 2 wheel drive seems to be dolly. I would suggest a light hitch to move dolly around.
    You are right the '96 & '97 c without 4X4 cannot be towed four down. I just looked at the towing guide and it didn't mention that, just info on 4X4's.
  • Is the Tracker 2 or 4 wheel drive. If 2 wheel drive it cannot be towed four down. Using a dolly needs to be rear end on dolly.
  • If I were to tow a car that was not towable four-down like your's is, I'd use a dolly. But with a vehicle like yours that can can be towed four-down, that's what I would do. Hubs and a brake system less than an new trailer or dolly. An aux brake system can be bought used on CL for a lot less than new.
  • Trailers are great, they have their own brake system and lights plus they tow easy.
    The draw back is they require space in the camp ground.
    We've often left our trailer in a parking lot before we camped. Most times we could get the whole rig in a pull thru space.
    We only needed a 16' trailer for all we carried.
    Other thoughts, you still must have tie downs to keep the load on the trailer
    But you can back up.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 15, 2025
