Try it on electric. Does it show AC on the eyebrow (Control panel) Good.
Do this when it is warm
Find the electric heat element the large metal tube on the right (outside) has two (well now days 4) wires going to it. two go to a push button. ignore those if it is working on propane they are good.. The other two go to a kind of "probe"
Find a test point (the other end of them) and see if 120vac is present
YES: control board good
now disconnect and see if they show resistance between them (on the order of 0.3333 ohms give or take a bit, near short) NO. Electric element bad..
Any RV dealer should have a replacement You may have "Fun" getting the old oneout it's the Probe like thing the wires attach to.. and the more than likely the wires)
