โJul-25-2017 08:02 AM
โJul-26-2017 06:34 AM
โJul-26-2017 03:47 AM
jstaffon wrote:I was asking the same questions recently. Here is something that really helped. I gave this document to my electrician and it confirmed what he was thinking.
Thanks all for your replies! My plans are to install a 20 or 30 amp service for my RV. Having AC while in the driveway is nice when working during hot weather. I also think I'm having icing issues. Does anyone know if you can tie a low voltage or low power condition to icing? Thanks.
delwhjr wrote:
Get this document:
30 amp wiring
It is a pdf. Print it and give it to him.
โJul-25-2017 07:37 PM
โJul-25-2017 06:01 PM
โJul-25-2017 05:56 PM
2012Coleman wrote:OP wrote:Maybe I'm misinformed, but I thought that you could not run the AC on household current. I'm not an expert in electricity, but I'm guessing CW plugged into a 30 amp plug. I just had one wired for me at the new house. It's nice having a cool TT to load/unload/do repairs on.
When we returned home, we parked the RV in the driveway and hooked it up to 110 vac, 15 amp service using the 50 amp cable and a couple pig tails to get it to the right connector to plug in the outlet.
โJul-25-2017 05:52 PM
dkreuzen wrote:
It sounds like the fan was running and blowing ambient air. I have Coleman Mach 15's on my coach and more than once I have has the same thing happen. It seems to happen when very hot outside (110+), dry, and the coach is hot inside (90+). I have full air flow out the vents so it is not icing up. If I turn off the unit for a minute then back on it will works fine. I think the compressor is overheating and shuts off. It won't come back on without shutting it off and back on. I also notice that if I do not allow the inside temp to get above 85 of so it will stay running even at 115 outside.
In your case the 15amp extension cord could be overloaded causing a low voltage issue too.
โJul-25-2017 05:48 PM
ScottG wrote:
I'd also guess that it froze up. You could start by making sure the filter is clean. Also, make sure the fan is on "High".
โJul-25-2017 02:25 PM
โJul-25-2017 10:51 AM
โJul-25-2017 10:34 AM
โJul-25-2017 09:05 AM
โJul-25-2017 08:33 AM
โJul-25-2017 08:12 AM
