door latch does not work on outside pull
klipper849
have a 2008 Monaco caymam and our outside door pull wont open the door someimes,works fine on the inside pull.any ideas.ed
5 REPLIES 5
RoyB
I think my 5th wheel trailer door is starting to do the same thing. I can help it alot with a good soaking with WD40.
I too can open it easier by pulling on the latch and pushing on the door at same time.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
ctpres
This worked for me.
With outside paddle held open by third hand on inside paddle, I could see a metal ramp (part of paddle) that raised a white plastic cam. Surface of both parts had 33,000 miles worth of dust and dirt making operation rough. No way to clean or smooth rough surfaces without taking it apart. So I put spray tube on silicone and blasted it reasonably clean. Also lubed latch bolt same way.
2,000 miles and three months later SMOOTH operation.
A "Retired" Mind is a Terrible Thing to Waste
Chuck USNR, USAF & USCGA and Suzie
Challenger Owners Club
2015 Thor Challenger 37KT
2014 Ford Fiesta
2011 Sea Eagle 385 FT kayak
2009 Polaris RZR
2014 Zenetto Stealth road bike
snowdance
Have been thru that many times over the years.. Go out side and push (not pull) on the door with one hand while you open the latch. If it works what you will find is the movement going down the road has worn a grove in the latch bolt from the striker plate. So if you pull the bolt is set in the grove from the striker plate and you can not move it. You can file it smooth again. Also best way to keep the door shut when moving is a dead bolt. And they will come up with the same problem over the years..
Snowdance
We spent most of our money traveling... Just wasted the rest..
Chevy 7.4 Vortex
2000 Jamboree 23b Rear Kitchen
http://www.flickr.com/photos/snowdance38
1SG
I'm not sure how the door latch mechanism works or looks like but you should go over to IRV2.com and ask this under the Monaco forum.
I was having the same trouble with my 2006 HR Endeavor and found the answer to the problem with that group I was shown how to adjust the latch mechanism and my door works perfect now.
Paul
Paul & Sandy
2018 Tiffin Allegro Bus 40AP
'56 Ford Customline Victoria
'62 Chevy Impala SS 409/4spd
U.S. Army Retired
Cloverdale, OR
restlesswind
You might check if there is an adjustment possible either on the door or the door frame.It could be that the part on the door frame has loosened and moved
from it's correct placement.
It could be that the lock/latch mechanism need to be replaced.
Check the simple/cheap things first.
'04 33.5 CKQG Hitchhiker Discover America
04.5 Dodge 3500 CTD SRW
Pac Brake,Max Brake
Fulltimers since '06
