  • Ideally, the tongue weight should be about 10-15% of the trailer's total weight. You can adjust the weight distribution by moving cargo within the trailer or using a weight distribution hitch. This can help prevent trailer sway and improve your vehicle's handling and braking.
    On a related note, I edit videos for my YouTube channel and I'm currently working on a video about trailer safety, including tongue weight. For my video editing, I use Movavi because it's user-friendly, offers great editing tools, and has fantastic customer support. If you're interested in learning more about video editing, check out this guide: https://www.movavi.com/support/how-to/automatic-video-editor.html
    • valhalla360's avatar
      valhalla360
      Navigator
      It's a 7yr old post you are responding to.
      That said:
       - 10% is marginal. 12-15% is good. More is better but other issues usually start to get in the way (most common is the truck can't handle the higher hitch weight.
       - Also a WDH won't fix a bad weight distribution. WDH helps with a front truck axle that becomes too light due to hitch weight reducing the front axle weight.
  • Thanks for posting that video. I had seen it before but forgot about it and just used it in another thread where it fits perfectly into the discussion here.
    Barney
  • Fixed the title from "Weight Distribution" to "Tongue Weight" to try to clear that up. Thanks.
  • Hi,
    Here on the towing forum, the words "weight distribution" make us think of the weight distribution hitch between the camper and the truck.
    In this case, the video is showing the effect of how a loaded camper tongue weight affects stability of the camper and tow vehicle. Yes, the weight distribution of having the proper trailer tongue weight balance per the trailer gross weight is not correct.
    It is a good video to help show the point. Thanks for sharing this. It should help many visualize the problem.
    Thanks
    John
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,107 PostsLatest Activity: Jan 29, 2025
