PeteK-Hou's avatar
PeteK-Hou
Electric Tongue Jack Flange
I'm looking to buy an electric tongue jack. The jack I have now (manual) connects to the A-frame using a 'triangular' flange. Most of the electric jacks I see have a circular flange. Are these interchangeable?
  • Thanks downtheroad. I figured they would be interchangable, but there's nothing like confirmation.
    Thanks again
  • Yes. They all have a 3 bolt install pattern. Should work just fine. Make sure you order the correct shaft size. I'd order the larger of the 2 that are offered. If you need to, it's easy to, "hog," out the opening slightly to allow the new jack shaft to slide in.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 18, 2025
