270wsmhunter
Aug 05, 2016Explorer
Equal-i-zer, keep as is or remove washer?
Finally got the truck and camper to CAT scale today, Equal-i-zer 14K hitch. Truck was filled with fuel, generator and bikes in back, hitch on, tools in cab with me, trailer loaded with most stuff and full tank of fresh water.
Truck alone:
Steer axle 4720 lbs
Drive axle 3680 lbs
Gross weight 8400 lbs
Truck with camper no weight distribution:
Steer axle 4360 lbs
Drive axle 5000 lbs
Trailer axles 7040 lbs
Gross weight 16400 lbs
Truck with camper and 4 washers weight distribution:
Steer axle 4480 lbs
Drive axle 4840 lbs
Trailer axles 7100 lbs
Gross weight 16420 lbs
Truck with camper and 6 washer weight distribution:
Steer axle 4740 lbs
Drive axle 4420 lbs
Trailer axles 7220 lbs
Gross weight 16380 lbs
My instinct says to remove one washer to get front axle slightly lower than when truck is by itself. I thought I would ask on here before doing so tonight. Any input is greatly appreciated.
Truck alone:
Steer axle 4720 lbs
Drive axle 3680 lbs
Steer axle 4360 lbs
Drive axle 5000 lbs
Steer axle 4480 lbs
Drive axle 4840 lbs
Steer axle 4740 lbs
Drive axle 4420 lbs
