burnmark's avatar
burnmark
Equal-i-zer
We just switched from a basic WDH with friction sway control to an Equal-i-zer. This was due to some uncomfortable towing issues with the new TT.
If you have considered this move, it is night and day for balance, control and comfort driving. Wish I had done this long ago.
  • DutchmenSport wrote:
    I went from an old school style Reese WDH (with the chains) and friction sway bar to the Equal-i-zer as well. However, I do not notice any difference towing. Both gave me a comfortable ride. Part of that might be due to my tow vehicle. The advantage of the Equal-i-zer over the standard Reese is, no need for the sway bar any more, and can back-up without having to first remove that sway bar. Disadvantage of the Equal-i-zer? It pops a lot, which I finally accepted as normal. I did purchase a set of those pads that fit on the trailer frame (L bracket) that's suppose to help reduce that popping. I can't say that insert makes any difference either. However, after having both, if someone offered me 2 brand new one (Reese or Equal-i-zer) for the exact same cost, I'd now take the Equal-i-zer.
    But what you are comparing is apples to oranges! Reese has the Dual Cam system which is integrated like the Equal-I-Zer is, though a different design. Reese also has a system which is very similar to the Equal-I-zer 4 way sytem called the SC (I think it is). Both of those Reese systems allow you to back up just like the Equal-I-Zer system without removing anything.
    I do agree with the basic system you had comared to the integrated system you now have. While I haven't used an Equal-I-Zer system, my buddy has one, and if I had to choose between the Reese DC/SC or the Equal-I-Zer 4 way system it would not be easy!
  • I went from an old school style Reese WDH (with the chains) and friction sway bar to the Equal-i-zer as well. However, I do not notice any difference towing. Both gave me a comfortable ride. Part of that might be due to my tow vehicle. The advantage of the Equal-i-zer over the standard Reese is, no need for the sway bar any more, and can back-up without having to first remove that sway bar. Disadvantage of the Equal-i-zer? It pops a lot, which I finally accepted as normal. I did purchase a set of those pads that fit on the trailer frame (L bracket) that's suppose to help reduce that popping. I can't say that insert makes any difference either. However, after having both, if someone offered me 2 brand new one (Reese or Equal-i-zer) for the exact same cost, I'd now take the Equal-i-zer.
  • You did the right thing. The Equalizer and a couple of other mid priced integrated WD/sway control systems can add great comfort to towing resulting in a much more enjoyable experience. I use a Reese HP Dual Cam system and like you previously had the friction bar before and the difference is just astounding. After 8 years of using it I still enjoy the journey.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 16, 2025
