โMay-16-2015 05:48 PM
โJun-10-2016 03:33 PM
The LeRoys wrote:
3)Van same as above. Trailer level front to back, Hitch with all 8 washers, L brackets as high as they go (as much WD as can be enable)
Front Axle 3280 lbs
Rear Axle 5540 lbs
Approximate Tongue Weight 1320 lbs
Tongue Weight Percentage 13
Tongue Weight on Front Axle "negative 120lbs"
Camper Wheels 8800 lbs
Total Camper Weight 10120 lbs
4) Van same as above. Trailer one to two inches lower in front than rear, Hitch with all 8 washers, L brackets as high as they go (as much WD as can be enable)
Front Axle - 3380 lbs
Rear Axle - 5380 lbs
Approximate Tongue Weight 1260 lbs
Tongue Weight Percentage 12
Tongue Weight on Front Axle " negative 20lbs"
Camper Wheels 8840 lbs
Total Camper Weight 10100 lbs
5) Van without Trailer again .All the crew and most of our stuff, filled Gas tank
Front Axle 3400 lbs
Rear Axle 4100 lbs
6) Van same as number 5, trailer added some groceries. Trailer three to four inches lower in front than rear, Hitch with all 8 washers, L brackets as high as they go (as much WD as can be enable)
Front Axle 3340 lbs
Rear Axle 5720 lbs
Approximate Tongue Weight 1300 lbs
Tongue Weight on Front Axle "negative 80lbs"
Camper Wheels 8880 lbs
Total Camper Weight 10180 lbs
โJun-10-2016 09:05 AM
โJun-10-2016 06:00 AM
โJun-10-2016 05:56 AM
โJun-10-2016 05:53 AM
โJun-10-2016 05:47 AM
โJun-08-2016 02:44 PM
โJun-08-2016 12:01 PM
โJun-07-2016 08:08 AM
โJun-07-2016 06:29 AM
โJun-06-2016 08:12 PM
โJun-03-2016 10:07 AM
โMay-29-2016 08:05 PM
edm3rd wrote:
One thing that was mentioned very early in this thread. New tires need about 500 miles to wear off the "mold release" used in the manufacturing process. Don't judge your Michelins until you have some more miles on them. I have noticed this on all Michelins I have installed, and Tire Rack also cautions about it.
โMay-29-2016 08:04 PM
