WBVenard's avatar
WBVenard
Flat towing a 2017 Ford Fusion 2.7L, AWD w/auto trans.
I am thinking of buying a 2017 Ford Fusion, 2.7L, w/auto trans, and I am interested if anyone has had trouble running the car battery down while towing with a supplemental brake box.
I presently have a 2012 Ford Fusion Hybrid which has serious problems of running the car battery down after only 3 or 4 hrs. of flat towing with a supplemental brake box. I tried many things to fix the problem without success. A car dolly solved the problem, but it is too inconvenient.
  • 2017 Fusion Owners Manual Pg 226:
    All-wheel Drive Vehicles
    All-wheel drive vehicles CANNOT be flat-towed (all wheels on the ground) as vehicle or transmission damage may occur. It is recommended to tow your vehicle with . all four (4) wheels off the ground such as when using a car-hauling trailer. Otherwise, you cannot recreational tow your vehicle.
  • So, I read both of your posts asking basically the same question about two different vehicles, and the answer is it doesn't matter what vehicle is being considered, any "brake in a box" that uses battery power from the towed vehicle will deplete that vehicle's battery. The solutions are a) run a charge line from motorhome to toad to keep the toad battery up, b) use a "battery box" (a portable battery booster with it's own battery). Some members on here have reported success going this route. c) Get a braking system that doesn't need power.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
