Considering the Flojet system for dumping at home into our septic clean out. Our clean out is behind our home and no way to get RV close to it. I saw a thing from the manufacturer that with a 3/4" hos...
I trenched and buried a 1 1/4 inch 130 feet long pvc pipe with a male hose fitting on each end. I ran the pipe to green valve box on each end and use two short 3/4 inch hoses - one to connect to the macerator and the other to the sewer clean out. After flushing for about 5 minutes with fresh water per the macerator instructions I store the 3/4 inch hoses in a plastic tub.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 25, 2025
