For those that like this style air compressor
wanderingaimles
Horrible freight has put one on sale for Black Friday
Small comp
OK, now let the haters begin.
19 REPLIES 19
bucky
time2roll wrote:
Have had similar for 15+ years. Re-tapped the outlet to use a standard hose and chuck. As long as it has battery terminal clamps it is probably decent.
I see you figured it out also, the screw on attachment is a royal pain. A dually makes it even worse.
Puma 30RKSS
ROBERTSUNRUS
🙂 Hi, I bought one of those Harbor Freight compressors many years ago. If you run it without being attached to a tire valve, it will blow up. Well at least mine did. I took it back as defective for a warrantee replacement and was hassled, but they finally gave me a new one. I installed a compressor blow off valve and never had a problem since.
🙂 Bob 🙂
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
time2roll
Boon_Docker
Bobbo wrote:
I have one exactly like that with a different label. It is actually an excellent 12v air compressor.
X2
I have the same unit, different label. Used it many times and no complaints.
Bobbo
Bobbo and Lin
