EB Expedition wrote:
We just purchase a Class A motorhome and are looking at purchasing a Ford Focus as a dingy. The owner's manual states as part of the tow preparation to disconnect the negative battery cable. Does anyone have experience with this Ford or similar product? Any information is greatly appreciated.
I towed my 2012 Focus around a parking lot with the battery connected to see what would happen. I figured the low speed/short distance wouldn't cause any mechanical harm. This ended up registering a transmission (TCM) fault code, a hill-start assist fault code, an ABS fault code, and the odometer registered the distance pulled. I had to pay the dealer to clear the codes.
You must disconnect the battery. You CANNOT disconnect it at the firewall. Doing so will not fully disconnect the battery. You
must disconnect a post. I have disconnected the positive terminal in one test as it is much easier to get to and, electrically, it is the same thing UNLESS there are capacitors in the system. Regardless of which terminal you disconnect, you will get an ABS fault and a hill start assist fault on reconnection. Both of these faults will self clear after driving the car a short distance (~1/4 mile). Once you reconnect the battery, you MUST drive the vehicle within 15 minutes or the fault codes will not self clear and you will have to go to the dealer.
Disconnecting the battery is a pain, but you do not have to re-program the radio if you have the Sync system. The only thing you need to do is set the date and time and, if you have one touch windows, you will have to re-program them as well.
RK
