Howie3
May 12, 2015Explorer
Ford SYNC trailer app says I'm towing
The computerized dashboard with my trailer package displays when my trailer is connected. This is handy not only for indicating the level of the brake controller but will show 'trailer disconnected' when the plug is removed. Awhile back, this alerted me when I didn't push the 7 pin plug in firmly enough and disconnected while traveling. I was able to pull over immediately before I found out the hard way that I had no trailer brakes.
So the other day I pulled the trailer out for spring maintenance and when I unhitched, the dashboard still showed trailer on. Every time I start the truck, the trailer app is showing up as reading a trailer attached.
Has anyone with Ford's SYNC trailer app experienced this, and if so, how did you solve it?
