BarneyS
Aug 13, 2017Nomad
Yes you should use a sway control of some kind. The manufactures of the hitches usually do not recommend using a single friction sway control on trailers over 26 feet long. You should use two of them on trailers longer than 26 feet.
Better yet, get a WD hitch that has sway control built in like the Reese Strait-Line (Dual Cam), the Equal-i-zer 4 point, or some others. I don't know anything about the Curt Trutrack but think you can do a bit better than the E2 for that size trailer. Please don't cheap out on the hitch.
I agree with the above posters who said to check your weights. Most people are very surprised when they finally get around to a scale and actually weigh their rigs. I tow my trailer with a 2016 Ram 2500 with the CTD and my rig has a tongue weight in the neighborhood of 1350-1400lbs. It was advertised as around 850lbs!
Barney
Barney
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 01, 2026
