You don't say where you are or what the ambient temps have been - that information would be helpful. Here are some of the things full-timers do to help mitigate heat/cold:
1) Cut Reflectix (bubble-foil insulation) to fit in the windows during very hot or cold weather (in your Class C, the front windshield is a HUGE loss/gain factor).
2) Buy the insulated cushions to fit in any roof vents you have while they're not in use (i.e. in the bathroom).
3) Use the awning to shade the sunny side of the rig when possible (do not leave it out when you're gone).
4) If your thermostat allows, set it to "High Cool" rather than "Auto." The fan will run on high all the time keeping air circulating and the compressor will cycle as needed. This also reduces the chances of the coils freezing up if you're in a high humidity area.
Many full-timers get years of service out of the ACs. Get it serviced annually to have the coils cleaned, etc. (or do it yourself). It's there for a purpose - use it and repair/replace as necessary. Since they are sealed units, there's little else you can do other than keep everything clean.
Rob
