BigSur2
Feb 11, 2015Explorer
furnace freeze?
Guys, had issues last night with regulator freezing up...couldn't get any propane flow at all. Got that resolved. Propane is flowing now but the furnace will NOT fire off. Any ideas, advice, etc????
bsinmich wrote:
Most dehumidifiers do not move air outside of the vehicle. They pull air over cold coils and exhaust the same air the out over the condenser coils so it should be slightly warmer but have less moisture in it. The moisture got removed at the cold coil.
CavemanCharlie wrote:
I suppose it possible that the water in the propane tank that made the ice that froze up the regulator also got to the control valve for the furnace and froze in there as well. But, you'd think it would melt out after awhile if it's warm inside the camper.
