MadFinnHockey's avatar
Jun 01, 2017
Generator question
I have the opportunity to purchase two slightly used Yamaha EF2000IS generators for a pretty fair price ($900 for the two). If I get them I'd buy the interconnect cable so I can run both and run everything in my camper, AC included.
They've been sitting with full gas tanks for a bit and haven't been run in awhile.
They start with one pull, but one but will only run smoothly and stay running with the choke out, once you start closing it, it starts to cough and will eventually die.
The other runs a little rough with the choke out and stalls when pushed in.
I've checked the voltage output (both 120vac and 12vdc outputs) and they're fine.
I'm "assuming" the carbs are gummed up / dirty, and a good cleaning may take care of it, but I'm not mechanical enough to tear them apart and do that. Or maybe a little Sea Foam will clear it out?
I'm open to your thoughts, and thanks
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,173 PostsLatest Activity: Oct 24, 2025
