โMay-28-2019 08:14 AM
โMay-29-2019 07:53 PM
RobWNY wrote:
Yes, the original tires were Load Range D tires.
โMay-29-2019 05:37 PM
โMay-29-2019 05:06 PM
Cummins12V98 wrote:
Do what ya want but proper inflation is critical for ride, stopping and tire life.
โMay-29-2019 04:31 PM
โMay-29-2019 04:26 PM
RobWNY wrote:Cummins12V98 wrote:
I assume you up sized in load range. Weigh your rig. Use load/inflation chart for your tire and add 5psi. This is per GY Tech Support.
Help me out on this. My camper weighs in the neighborhood of 9700 pounds when loaded, give or take a few hundred pounds. It depends on what we're bringing with us on any particular trip. The stamped maximum load capacity on the rims is 2830 pounds, the same as what is on the Goodyear Endurance ST 225/75R15 E rated tires. From what I can tell on the chart, it says 80 PSI. Are you saying to air them up to 85 PSI Cold?
โMay-29-2019 11:42 AM
MFL wrote:
Rob... what Ron means is to weigh each axle/tire, and look up load chart for the weight of the heaviest tire/wheel, then add 5 lbs to whatever the chart recommends. Myself...I'd just go 75 lbs. minimum, but likely would use 80 psi, to take full advantage of the E-rated tires, as well as keep them running cooler. JMO
Jerry
โMay-29-2019 11:30 AM
โMay-29-2019 10:00 AM
Cummins12V98 wrote:To gain the additional load capacity.twodownzero wrote:A RV that has D tires that inflate to 65 based on max load. Now has E why run max?
Air your tires up to 80 psi and don't worry about it.
โMay-29-2019 09:56 AM
philh wrote:Turtle n Peeps wrote:
Kill the high side alarm and keep the low side.
If you really want to end this business; drain and fill the tires with nitrogen 3X's. That will stop all of this.
Nitrogen is a scam
OP, what does your high quality tire pressure gauge read in comparison to your TPMS read out? that will tell you what pressures you need to know.
I have no idea what Nitrogen 3X is, but if it's being sold as a tire solution it's a scam.
One of the common statements supporting N, is water vapor in air. Most (all?) tire shop air lines go through a water separator filter. Is it completely dry, no, but it's dry enough. Tire temperature would have to get deep into 200ยฐF to "boil" the water vapor. If you're tire is 250ยฐF, you're already in deep doodoo.
โMay-29-2019 09:42 AM
โMay-29-2019 09:17 AM
Because that is what Goodyear recommends, that is what will keep your tires from getting hot and failing, and because there is absolutely nothing to gain from inflating the tires to anything less than the maximum. I'm pretty sure we've had this discussion before and you have your position and I have mine. While truck tires should be inflated based on load, trailer tires should be inflated to their sidewall maximum.
โMay-29-2019 08:34 AM
โMay-29-2019 07:12 AM
โMay-29-2019 06:30 AM
