โDec-07-2014 04:07 PM
โDec-19-2014 07:15 PM
Sport45 wrote:atwowheelguy wrote:sgrizzle wrote:
I see the Maxxis M8008, with the 10 ply that is rated at 80 psi...
How do I know if my rims are compatible?
This information was on my cast aluminum wheels. Note that the wheels are rated for 2830# load, which corresponds to load range E, 80 psi. When they were 5 years old, I replaced the original ST205/75R15C (1820# load) with ST225/75R15D (2540# load).
I bought the Maxxis tires.
You sure about that 2830# load rating? I only see 5 lugs.
MAX LOAD
GIBBERISH
2830 LBS
โDec-19-2014 04:11 PM
ScottG wrote:
Get the Maxxiss' and forget about them.
โDec-19-2014 03:55 PM
โDec-19-2014 07:01 AM
โDec-14-2014 03:27 PM
Moderator edit to re-size image to forum limit of 640px maximum width.
โDec-14-2014 06:22 AM
Here is Michelin LTX M/52
Does this sound like a decent LT? The 2,200 per tire, would be at my axle limit of 4,400 lbs. Is that ok?
Also, would this be firm enough to help reduce any sway?
โDec-14-2014 04:58 AM
โDec-13-2014 07:26 PM
Sidewall Style: Outlined White Letters
Serv. Desc: 108T (2200 lbs per tire) T - 118 MPH uhhhh, no)
Load Range: XL (42 psi??)
โDec-13-2014 06:50 PM
โDec-13-2014 06:41 PM
โDec-13-2014 06:35 PM
โDec-11-2014 03:43 PM
โDec-09-2014 03:45 AM
ScottG wrote:dodge guy wrote:
They don`t make an "D" or "E" rated LT tire in a 15". I went with Carlisle ST "E" rated tires. very glad I did despite what people post about them. all the failures in my research were in the "C" rated tires.
All 5 that came with my TT were LR D and failed on their own.
I've read plenty of posts about the higher LR's failing.
Good luck.
โDec-09-2014 03:41 AM
With the E tires what pressure do you have in them? If you went from C to E tires did you find the trailer has less sway?
โDec-08-2014 05:59 PM
I am considering replacing them with LT tires.
My Trailer:
GVWR is 7900 lbs.
GAWR (each Axle) is 4,400 lbs.
Max Cargo is 1,460 lbs.
How do I choose the best match in a LT tire. I have tried looking at Tire Rack and michelin sites and it gets pretty confusing. Thanks for your help!
