Atlee's avatar
Atlee
Apr 25, 2016
Haste makes waste is an old adage, but still true.
Yesterday, coming back from a weekend outing at a spring football game, I went by the CAT scale at the local truck stop. I didn't have a chance to weight it before leaving. The FW tank was only 2/3 full, but the BW tank hadn't been dumped yet. Those weights offset each other, except for weight distribution. FW tank is slightly forward of the axles, and the BW tank is slightly behind the axles.
In any case, I went across the scales got my weight, and then swing around in order to go accross the scales with the WDH bars disconnected. I wanted to get a general idea of the tongue weight.
Cognizant of the fact what I'm doing is recreational, but what the truckers are doing is their lively hood, I didn't want to be in the way any more that possible. So I ran out, put the power hitch down in order to release the bars. I quickly got back in the truck and pulled to go on the scales again.
It didn't want to go, and I heard a scraping noise. Yep, I forgot to lift the hitch. Now, I had destroyed the post assembly on my Barker. Even worse, I couldn't move it enough to get it off the ground.
Finally two truckers came over, and helped me out. Through their brute force they were able to pull the bent post up through the hitch hole. They used some straps and bungie cords I carry to tie it into position so I could drive home, which is fortunately just 4 miles away.
In any event, these are the weights I got, and I'm well below all the top limits. My truck has a 4050# front axle and a 4800# rear axle and a GVWR of 8200# with a CCC of 2286#. and a GCWR of 17,100#
With out the trailer (weighted it before I left) but loaded with all the stuff I carry, including tools, 2 generators, 13.5 gallons of gasoline, a 2.25 ton floor jack, and small air compressor, but without DW who weighs 125#. The front axle weighed 3620#, rear axle was 3280# with total weight of 6900#. The combined truck/trailer with equalizer hitch was FA 3480#, RA 4040#, trailer 4440# for a total combined weight of 11,960#.
I still have to figure out what my tongue weight is.
  • On my second camping trip with the new trailer, I had adjusted the bars and put the jack up just enough to put all of the weight on the tongue thinking that I would put it all the way up before I pulled out. I then pulled forward to remove the leveling blocks from the wheels, continued with everything, and completely forgot the jack was still mostly down. The campsite had a small lip between the gravel pad and the asphalt road. As I pulled out, I heard a scraping sound, but being a newbie I thought it was just the WD bars making noise. I didn't hear anything afterward, so I started on my way. Thankfully the camp host was paying attention and flagged us down in his golf cart. Sure enough, I bent my brand new jack. I was able to get it up and I'm still using it. It bogs down a little, but not too much. It's a good reminder to me to check everything before pulling away. One of these days I'll replace it, but I'll probably end up putting it on the horse trailer.
  • we did that with our barker. went into a store parking lot once and the guy helping me hook up didn't bing it all the way up. when we got to the fishing hole we ran a log chain under the truck,wrapped it around the post and then hooked up to another truck and backed up. straighten right up. used that jack for 20 years after that, and I'm not kidding. it was one great jack.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
