vlopddap
Jun 02, 2014Explorer
BarneyS wrote:
The maximum number of washers is the number that will fit on the pin going through the center of them. I believe that it will hold about 8.
Barney
Okay if I correctly understand the basics of the WD hitch adjustment process, if I reached the limit of 8 washers and the weight transfert is still not enough (it won't be the case necessarily since I'm 6 washers now), next step is to raise the L-brakets from a hole higher? But in that case I'll probably need to remove a few washers because both of the L-braket's height and number of spacer washers work on the shank angle which act directly on the torsion bar and with the weight transfer?
I understand that more strength you put on the torsion bars, the higher will be the weight transfer to the front? Actually the torsion bars are very easy to slide on the L-brackets (by hand, no pry bar needed), so that's probably an indication than the weight transfert is too light right now?
Thank you very much for all your help!!
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
