rferoni
May 25, 2015Explorer
Ok thanks y'all. Right now that jack screw isn't even hitting/resting on the shank. Above the jack screw there is another sort of 'bolt'(not threaded) that has some washers on it. Looks like you could add/remove washers?? This part is resting against the shank.
I tried to go to 4 chain links but the brackets are so low I can't get the pipe underneath without the pipe hitting the ground. Yes I can get a different pipe or maybe put a bend in it just haven't had the chance yet.
I think the ball was tilted toward the trailer when we set it up. I'll get the ball straight(level) and redo everything from there.
Question...Do I adjust the tilt while everything is hooked up? I mean with the w/d bars tightened down and everything? If so, how exactly do I do that? Do I need to loosen the bolts holding the hitch head to the shank, or just crank on the jack screw?
Thank you all again for the input,
Ron
Ron
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,114 PostsLatest Activity: Feb 24, 2025
